Howto set a maximum Z value as surface constraints for a LAS dataset
993
11-06-2012 05:41 AM
henkkramer
I have a LAS dataset with some high Z values that are errors in the dataset.
I would like to set a maximum Z value as a Surface Constraint so all point with a Z value higher than the given value are filtered from the dataset. I tried to use a polygon feature with a maxZ value as a Surface constraint but that does not work.
How can I set a max Z value as a filter on the LAS dataset?
Henk
Tags (1)
