How to split a TIN surface by a Polygon
2435
08-09-2016 09:13 AM
SaadHumaid1
Hi
I am an ArcGIS new user, as I am relatively new in the GIS Field.
I am trying to do quantity take off using ArcGIS.
here is the problem I am facing:
I have polygons that represent the plots for a specific area
and I have paving surface (tin surface) that represents the paving.
I am trying to divide (split) the paving based on the plots polygons, so that I will get a separate paving piece for each plot.
what tool shall I use in order to cut my paving tin surface based on my plots polygons? after cutting the tin surface into multiple ones, will I be able to get the 3D area of the paving per plot ?
Thanks
DanPatterson_Retired
Since you are new to gis and TIN data structures, here is a link to some of the reference materials
An overview of the 3D Analyst toolbox—Help | ArcGIS for Desktop
An overview of the Triangulated Surface toolset—Help | ArcGIS for Desktop
you may find it useful to work with rasters in some instances, since there are cut and fill tools
I am also going to move this to 3D​ to get a more targeted audience
NeilAyres
Is there any reason you want the true 3d distance / area for this?
Unless your plots / paving is on the side of the Himalayas, the angular difference given the size of the area will be pretty tiny.
