How to create breaklines for LiDAR Data? Error in height(DSM-DEM) with water bodies
15035
10
11-12-2013 11:12 AM
SamriddhiShakya
Hi everyone ,
I have liDAR data (LAS files) of a county and I want to calculate height of the features from it . I created multi-points for both bare earth and non-ground and also terrain dataset from it.However , I do not have the breaklinesfor my LiDAr data .From the terrain dataset ,I created DEM and DSM Raster and also got the height raster(DSM-DEM) of the features from it. However , I am having some errors with the height of some water bodies .Normally,water bodies does not have much height but I am having some water features having more that 10 to 20 meters of height .
When I checked for the error,I found that while making Terrain dataset ,the height of water features have been overestimated. Since I don't have breaklines for my data to seperate water features, I am not able to eliminate this error . Is there anyway that I can solve this problem or create the break-lines for my liDAR data.
Waiting for your kind response.
Thanks ,
Sam
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Sam,
If you think the answer was helpful you can use the "arrow" button in order to help other members find useful information:
More info here: http://resources.arcgis.com/en/help/forums-mvp/
Kind regards,
Xander
