Hello, I am trying to create a LAS Dataset. The original data can be previewed with LIDAR online previewer. Each time trying an error message pops up. I use ArcGIS 10.3 with 3DAnalyst. I simply follow the help. Regards.
5630
5
04-26-2016 03:51 AM
MalgorzataHanzl
Tags (1)
BenjaminMittler
What error message are you receiving? Also can you go through your process of creating the dataset.
AdrianWelsh
MVP Honored Contributor
Hi Malgorzata,
Like Benjamin said, I too would like to know what your error message said and what steps you took to get there. Is your original data in a .las format?
MalgorzataHanzl
Dear Both,
Thank you for the interest. Actually the only information on the type of an error I have got was that the background process produced a serious error and had to be terminated. The data has been bought from official source. And it is visible and all correct when previewing. Could this be that I use student version of the software? However the data is required for the education purpose .
Best regards
AdrianWelsh
Malgorzata,
Would it be possible for you to attach one of your .las files here for us to look at and try out?
BenjaminMittler
Under Geoprocessing -> Geoprocessing Options, check of the box that says "enable" under background processing. Then try creating the dataset again.
I wouldn't think having the student version would have any impact on this
* This is just a guess
