Heads-up: FileGDB import bug in CityEngine 2014.1 (short int fields imported as boolean object attributes)
4974
10-07-2014 04:40 AM
SimonHaegler
Dear CityEngine users,
Unfortunately, a bug was introduced in the FileGDB importer of CityEngine 2014.1.1703 which imports short int field data as boolean object attributes instead of number attributes. We take this very seriously and are preparing an update.
In the mean time, please use the workaround described in this ArcGIS knowledge base article to create long int values of any short int field data: 34315 - Change the data type for an existing field‌. long int fields will be correctly read by CityEgine 2014.1.1703.
Please accept our apologies for the inconveniences caused by this bug.
Kind regards,
the CityEngine dev team.
SimonHaegler
We are happy to announce the availability of a patch for the bug mentioned above:
Esri CityEngine 2014.1 FileGDB and CGA Compiler Patch | Samples and Utilities
The patch is available for Windows and Linux at this time - OSX will follow shortly.
Kind regards,
SimonHaegler
Finally we are also able to release the patch for OSX:
Apologies for the huge delay.
Kind regards,
