Error Exporting ArcScene to VRML
796
03-28-2024 08:51 AM
DanLewCSM
I converted some contour lines to a TIN surface using ArcPro and was hoping to use ArcScene to convert that TIN to a VRML file and finally to an STL file for 3D printing. I am having a problem where every time I export to a .wrl file, ArcScene crashes or does not respond. It would be great to have a TIN that I could use in Civil 3D, but ArcPro creates a TIN in a proprietary format that I cannot seem to export as a .tin. Has anyone else experienced this issue and found a solution?
Thank you
Tags (4)
