Draping layers on globe surface
1081
12-16-2011 05:04 AM
MarkCammarere
I have a globe document with several layers draped on the globe surface (e.g., use globe elevation as their own). If I add an elevation layer programmatically (that is, one that provides elevation information to the globe), how can I get the draped layers to use that elevation?
Tags (1)
JeffreySwain
Simply right click the layer and then set the base height of the layer to reflect the desired layers.  It is described in the help here.  You can path to any layer, it does not have to be in the document.
