Displaying well logs in Arcscene
2657
06-16-2012 01:28 PM
PierreAbadie1
Hello
I have well data in: LAT LONG DEPTH and X COORD, Y COORD, DEPTH.
The well log is a deviated well, not a straight well. If I post it in ArcMAp w/out using the z value, it shows the correct well deviation, posting each lat long coord and displaying a deviated well path.
Well when I open it in Arcscene and display XYZ, the well appears as a straight line.
Has anyone had any experience w this?   The data is point data.  I'm not sure if I have to do anything else to the data to get it to display correctly.
Any help would be very appreciative
Tags (1)
TarunJaiswal
Greetings!
Please refer to the following forum post as it may give you some pointers.
http://forums.arcgis.com/threads/54037-well-log-data-into-3d-analyst
Thank you.
