Dealing with large lidar dataset
1418
02-27-2013 09:38 AM
QassimAbdullah
Is any one aware of documentation on how to manage large lidar dataset in 3D Analyst (i.e. LAS->multipoint, ->Geodatabse>feature class etc.)? Thanks.
Qassim
Tags (1)
EricRice
Esri Alum
Hi Qassim,
These two links should get you going.  There are multiple ways to manage lidar data in ArcGIS.
Using lidar in ArcGIS
Common lidar data configurations
You may also want to review, LAS dataset considerations, should you take the LAS Dataset route.
Best,
Eric
QassimAbdullah
Thanks Eric for the prompt response. I have tens of large Lidar files (larger than 0.5GB each) and I am wondering if I can manage it in a geodatabse. Do you have additional links to show me how to take the LAS files into GDB? Thanks.
Qassim
EricRice
Esri Alum
You already touched on the answer.  See LAS to Multipoint.  I assume you will be building a Terrain from the data once it is in the geodatabase so be sure to output your multipoint feature class into a feature dataset.  Terrains must reside in a feature dataset and the source of the terrain must be in the same feature dataset.  It wouldn't hurt you to make a LAS Dataset directly from the .las files so you can QC it before loading into the geodatabase.
Best,
Eric
