cut fill in multiple areas
874
07-04-2013 12:09 PM
johngartner1
Hi - I am trying to calculate erosion versus distance downstream in a river.  I have two sets of lidar data, before and after a large event, and I can make a dem, terrain, tin, etc from these data.
I think the method is to use cut fill in several areas sequentially down the river, i.e the areas are polygons that are about 100 m long and about 80 m wide. But this gets tedious with over 200 different areas.
Is there a way to do a cut fill and then perhaps divide the results by the 100 x 80 m polygons? Or is there some other way to automate this process.
-John
Tags (1)
