Creating a 3-D model in a 2-D viewer. Can it be done?
1256
04-10-2014 07:42 AM
JamesMcBroom1
I am working with a 2D building footprints feature class, which contains a height attribute. I would like to create 3D extrusions from a given angle, but export them for use in a 2D map viewer, similar to classic Google Maps - you have a sense of the third dimension of each building footprint. I've attached a photo from Google Maps of the particular effect I'm going for. Is this possible in ArcMap/ArcScene? I've seen a YouTube tutorial that uses symbology as representation to create a drop shadow effect but I was looking for something slightly more real-looking.
[ATTACH=CONFIG]33015[/ATTACH]
Thanks in advance.
Jimmy
Tags (1)
I'm sure I've come across a 3D building style reference. That may be worth checking out.
