canot use 3d analyst in arcscene 10.1
9741
8
09-01-2013 08:39 PM
yangli1
[ATTACH=CONFIG]27144[/ATTACH]
i cannot use 3d analyst dropdown. and 3d analyst bar is grey. i have already check entenstion > 3d analyst.
Tags (1)
DanPatterson_Retired
Do you mean you went to Customize, Extensions and toggled on the 3D analyst extension? check on the toolbar doesn't enable 3D
yangli1
but how to enable it. thanks
PeterMacKenzie1
see attached img:
[ATTACH=CONFIG]27157[/ATTACH]
XanderBakker
Esri Esteemed Contributor
Hi yang li,
Judging from your first screenshot, the 3D extension is already switched on (otherwise the ArcScene and ArcGlobe icons would have been grayed out).
To enable the icons (functionality) on the 3D Analyst toolbar, you need to add data to your table of content. When you add a valid raster you will see this:
[ATTACH=CONFIG]27159[/ATTACH]
Most options are enabled, only the Profile Graph option remains disabled, since it requires a selection of 3D lines.
Kind regards,
Xander
yangli1
[ATTACH=CONFIG]27163[/ATTACH][ATTACH=CONFIG]27164[/ATTACH]
Hi yang li,
Kind regards,
Xander
hi Xander
actually, my situation is in the pictures i attched. i have already add validate data, but still cannot use some fuctions in 3d analyst tool bar, because in the dropdown there is just customize but no fuctions.
regards,
yang
yangli1
see attached img:
thanks, i have already done this.
XanderBakker
Hi Yang,
I suppose you have experience with ArcGIS 9.x and are used to find the functionality of 3D analyst in the 3D Analyst toolbar.
In 9.x you would see something like this:
[ATTACH=CONFIG]27167[/ATTACH]
All of these tools (and more) can be accessed now through the ArcToolbox:
[ATTACH=CONFIG]27168[/ATTACH]
This screenshot is from 10.2, but you will see something similar at 10.1.
Hope this is what you are looking for...
Kind regards,
Xander
yangli1
Hi Yang,
Kind regards,
Xander
thank u very much Xander!
