3D mapping Soil Nutrients, Chemistry and Microbe Communities
1000
11-19-2018 07:00 AM
JasonWilliams_James
I am going to be doing an academic project which requires me to take soil samples for laboratory analysis. Here are several questions which I need to understand.
  1. Am I correct in thinking the more sample locations used the higher the resolution?
    1. is there a tool in ArcGIS to create Sample locations to download onto a handheld GPS for fieldwork?
  2. I plan to drape these results over a TIN/DEM (is this the best way?)
    1. Do I need to create a different excel sheet for each depth and then use kriging tool for them and stack them draped of TIN/DEM ?
  3. Any advice for doing this with mixed microbe populations would be greatly welcomed.
Many thanks in advance
Luiz_AmadeuCoutinho
Hi Jason
1. More sample locations (points) are important to create a better surface. Check here to see about interpolation An overview of the Interpolation toolset—Help | ArcGIS for Desktop
   i. Here the tool to create random poins (samples) Create Random Points—Data Management toolbox | ArcGIS Desktop
2. I didn´t understand what you want.
3. Could you explain more?
