.LAS File Clipping
601
08-11-2019 09:46 AM
PhilFreeman
I am new to using these files and want to clip one using a polygon.  I thought the Extract LAS tool in 3D analyst would accomplish this.  When I try it, the tool gives no indication of an error and I obtain output, but the extent of the output .las file is the same as that of the input file.  Neither of them will draw on the screen, but I assume that is because of the huge number of data points.  I am using version 10.6 of ArcMap.  The input file has been classified.  Would that make a difference?  I assume I am overlooking something simple but just can't spot it.  Thank you.
