How to add buildings layer in Unreal Engine 5
1815
09-13-2022 05:52 AM
JakeUpfront
Can someone be so kind as to show me how I can add a buildings layer to my basemap in Unreal? I read the SDK and did the sample NYC project.  But I cannot bring buildings into my map. It would be great to have some easy to follow instructions on such a basic topic.
Can someone please helkp me with this? Im sure its very easy if you know how.
Thank you!
sjones_esriau
Take a look at the layers topic in the documentation and the sample it refers too.
https://developers.arcgis.com/unreal-engine/layers/
For example, here's the unity version in C# (that I'm more familiar with)
		var arcGISMap = new Esri.GameEngine.Map.ArcGISMap(arcGISMapComponent.MapType);
		// Set the Basemap
		arcGISMap.Basemap = Esri.GameEngine.Map.ArcGISBasemap.CreateImagery(APIKey);
		// Create the Elevation
		arcGISMap.Elevation = new Esri.GameEngine.Map.ArcGISMapElevation(new Esri.GameEngine.Elevation.ArcGISImageElevationSource("https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer", "Elevation", ""));
		// Create ArcGIS layers and add them to the map
		var layer_3 = new Esri.GameEngine.Layers.ArcGISImageLayer("https://tiles.arcgis.com/tiles/4yjifSiIG17X0gW4/arcgis/rest/services/NewYorkCity_PopDensity/MapServer", "MyLayer_3", 1.0f, true, "");
		arcGISMap.Layers.Add(layer_3);
		var buildingLayer = new Esri.GameEngine.Layers.ArcGIS3DObjectSceneLayer("https://tiles.arcgis.com/tiles/P3ePLMYs2RVChkJx/arcgis/rest/services/Buildings_NewYork_17/SceneServer", "Building Layer", 1.0f, true, "");
		arcGISMap.Layers.Add(buildingLayer);
What trouble are you having?
MounikaNamani
Have you done this? Could you please let me know how you did?
