How do I drape a surface on custom data rather than built in elevation data for a 3d web scene in cityengine webviewer app?
5740
04-06-2016 10:44 AM
JayHill
When I publish a web scene from ArcGIS Pro to ArcGIS Online for use in a cityengine 3d web scene, all of my surfaces that I have custom elevations assigned to come out flat. As far as I can tell the only elevation data that the 3d webscene will read or apply, is the built in esri elevation data.
I'm trying to display subsurface geologic data.
Tags (3)
JayHill
Sharing what I've learned so far, the easiest way to accomplish this is run the tool Export to 3D Web Scene in 3D Analyst Tools/CityEngine.
There are some limitations and specifics to know about although explained here.
http://downloads.esri.com/support/whitepapers/ao_/J10223_Exporting_ArcScene_Docs_to_3D_Web_Scene.pdf
Here is the result of my work.
http://arcg.is/1WsmG9X
The labels are 3D points with 3D character symbology.
NeilAyres
That's really good Jay.
Could you explain how you got the labeling organized please.
JayHill
Thanks Neil
I created a point feature class with a letter and a depth field. I placed each point by hand, guessing on spacing, in x,y space. Then I symbolized by the letter field with a 3D character marker symbol of the letter and rotated each one along the Y axis.
Then with the depth field I used that as the base height expression for the z space.
Hope that helps.
