Creating 3D object from two surface polygons
678
04-30-2019 06:10 PM
SRWHelpdesk
Gday
New to ArcScene (standard desktop license) wanting to create a 3D object from two Polygons that would be the top and bottom surfaces.  Both polygons are the same except that 2x scaling has been applied to the top one, so both polygons would have the same number of vertices.  Objective is to make a 3D object that resembles an extrusion to some extent but having different top and bottom surface areas. Appreciate any suggestions to tools or scripts that can help achieve this.  I have access to Spatial Analyst and 3D Analyst extensions if that matters.
cheers
