Copy polyline from 2D to 3D?
1086
06-21-2018 03:26 PM
JOHNDONALDSON4
On the right is a single row feature class polylineZ (with elev data) displayed on a new 2D map with no base map.
On the left is that same feature copied (using drag from contents pane) to a new 3D scene with no base map.
Why does the 3D look radically different? What factors would vary the image after copying from 2D to 3D? or is it something else I'm missing?
All I want is the feature to match. I am not groot. I am noob.
ArcGIS Pro v2.1.3
Why does the right 2D look so different from the left 3D?
Tags (1)
DanPatterson_Retired
can you zoom in on the left?
what elevation are you at in the 3D view?
JOHNDONALDSON4
Curiously, on the left, I can't zoom in any further because it just quickly disappears off the screen. That's the best I could do.
elev. 3100'
