2D Marker not visible through 3D Object (Indoor, behind 3D Object ..)
1999
02-27-2023 04:59 AM
ChristophHaeberli
2D Layer Features, symbolisced as 2D Marker, Relative to ground or relative to scene, are not showed when they are inside or behind a 3D-Object (Scene Service, like a Building).
Tranparency on the 3D-Object makes no difference, exept 100%.
Workaround: 2D Layer as Style 3D-Object
Any plans, that the 2D Symbols are also showing up, if behind 3D Objects? This is important for indoor sensors, Beacons, Analytic-Points (Noise, Visibility and more)
Tags (3)
ThomasKnabl
Hi @ChristophHaeberli,
ArcGIS Maps SDK for JavaScript 5.0 introduced improved occlusion handling for 3D labels and icons. Labels and icons can now remain visible when occluded by buildings, floors, or terrain, making it easier to work with indoor sensors, beacons, and analytical points in complex 3D scenes.
You can read more about the enhancement here:
This capability is now also available in Scene Viewer:
Thanks for sharing this use case with us.
GreteSoosalu
This is in our backlog but not yet planned for a release.
Thank you for sharing the use cases, this helps us to prioritize the backlog!
ThomasKnabl
ChristophHaeberli
Thanks @ThomasKnabl Looks good! Same Scene as before, the Icons are shown now
