when can "ArcGIS Runtime SDK" support LocalScene?
1520
12-17-2018 07:03 PM
aojie
When i use arcgis runtime IOS 100.4.0,I Find that:
【ArcGIS Runtime supports only scenes with the following values set:
  • version - 1.10.0 or greater
  • viewingMode - global
The "100.4.0" api  does not support local scenes, environment (lighting) settings, app metadata, presentation slides, clipping, range info, or vertical coordinate systems.
This means I must publish the data of WGS84 coordinate System or WGS84-Mercator.
The SceneView supports following coordinate systems in a global scene:
  • WGS84 or WebMercator
  • Noncached layers with any spatial reference since they will be reprojected to the scene spatial reference
In a local scene the following coordinate systems are supported:
  • Any Projected Coordinate System
I want to know when can it support LocalScene to  use the data of Projected Coordinate System. can the next API(100.5) support LocalScene?? when can the next api publish?
Thank U for all.
