Deep learning in 3D basemaps solution
6244
8
11-12-2020 06:16 PM
Gert_van_Maren
Esri Alum
2 8 6,244
The November 2020 solution release sees the first integration of deep learning into the 3D basemaps solution. Leveraging a new tree classification deep learning model on the Living Atlas, it is now possible to classify trees in lidar point clouds in ArcGIS Pro.
Before and after using deep learning to classify trees in the lidar point cloudBefore and after using deep learning to classify trees in the lidar point cloud
This solution release also adds a new density based cluster approach to tree extraction which significantly improves the tree extraction compared to a raster based approach.
Extracting tree location, height and width using density based clustering.Extracting tree location, height and width using density based clustering.
Just keep in mind that density based clustering on large amount of points is much more resource intensive than the existing raster based approach so we recommend using the latter first to get a generic tree coverage and use the density based cluster approach only for areas where you need accurate tree extraction.
For more information, see the 3D basemap solution documentation.
8 Comments
RickeyFight
@Gert_van_Maren
I cannot sign in and see this link above.
Gert_van_Maren
Esri Alum
Hi, the link is changed but Geonet is not updating.
For now, you can use: https://www.arcgis.com/home/item.html?id=58d77b24469d4f30b5f68973deb65599
Thanks.
PeterVickerman
I am attempting to use the deep learning to classify power lines in a lidar point cloud in the 3D basemap solution.
I have downloaded and ran the deep learning libraries installer but am unclear where the deep learning model files are located to actually use them in the solution.
I have searched my drive for any .dlpk and .emd files but nothing comes up.
have navigated to C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3 and searched there as well but I can't find anything.
Where can I find the model definition files or deep learning packages that were installed?
Gert_van_Maren
Esri Alum
PeterVickerman
Thank you!
OscarSolis1
Hi @Gert_van_Maren , i've tried to classify power lines with deep learning but it's not working well i suppose is beacuse the highg density of trees and vegetation, actually, i can't classify electric poles correctly neither. Any thoughs?
Regards
Gertvan_Maren1
Esri Alum
It could be that the model is not trained particularly well for your point cloud data and therefore giving incorrect results. You would need to improve the input training model using your own data in that case.
Regards Gert
OscarSolis1
