I have an existing survey that captures tree information; however, the hosted feature layer is becoming quite large so performance is really slow when refreshing the Inbox to edit data (even with spatial filtering enabled. Note: I've increased the maximum record count from 1000 to 10000). As a result, I've created a test hosted feature view from the main hosted feature layer for a particular area. I've created a second S123 form from the first survey, with slight default survey response differences (including a unique ID that concatenates the community being surveyed with time) & would like to use that against the hosted feature view. However, creating a new survey from an existing survey creates a new hosted feature layer. This is not what I want. I want the new survey to reference the hosted view. Is my only option to create a new survey from the hosted view and then edit the new survey to essentially look like the first?
Thanks.
