Hello!
I have followed the steps to change my basemap in Survey123 Connect to my personal web map. When I preview it in survey123 the map is there. However, when I preview the survey in a web browser the map seen is the World Topo Map. I can click on the basemap icon and select my map in the survey, but I want it to be the default. I have also tried changing it to the Open Streets Map and that didn't work as well.
This is the doc I used to guide me through the change.
Include a map in your survey—Survey123 for ArcGIS | Documentation
According to this the change should be automatic and I do not have to republish my survey. I have not tried to manually add it through code (a little uneasy about doing that at this point, but will try if I must).
Any suggestions? I attempted yesterday. Saved and closed everything. Tried again this morning with no difference.
This is a link to my survey:
https://survey123.arcgis.com/share/b8b74599ca0e48228323a2a455942aac?portalUrl=http://SAVGA.maps.arcgis.com
Thank you!
