I am trying to do a regex constraint on a field of type "decimal".
The regex is the following: regex(.,'^[+-]?[0-9]{1,2}\.[05]$')
What this says is that i want a number to looks like this: 10.5 or 6.0 etc..
The problem is that the regex evaluate to false when i place a 0 at the decimal. It correctly evaluate to true if the decimal is a 5.
If I use a field of type "text" the regex correctly understand the decimal 0 or 5, so the regex expression is correct. It seems to be a problem with fields of type "decimal".
Is there anyway to solve this? Is it possible to parse the number to text before evaluating it with the regex?
EDIT:
Ok this regex seems to work: regex(.+"",'^[+-]?[0-9]{1,2}(\.[05]{1})?$')
But somehow both regex I used allow for 10. or 5. for exemple (a number without any decimal)
