Hello! I've worked with Survey 123 a bit, and have experience updating a text field based on a change in a Select one Drop down list. This works great!
I have another requirement now for a 2-way update between two select_one drop down lists, and pulldata doesn't seem to work in this instance.
I have two Select Lists, with species scientific name, and then common name. What we want is, if either of the two lists are updated, the "other" name for the sighting will be updated. It could work both ways. A user could enter either the common name or the Latin name, and have the other one update. Using the same pulldata approach didn't do this.
I thought I read somewhere that this was not supported until v3. I upgraded and can't get it to work. Any thoughts? Thanks!!
