I'm trying my first survey with the geoshape. Is it possible to set the default location for the map when opening the geoshape question? I tried in both the default and calculations columns in the excel form but neither appears to work. I was hoping it would work like the geopoint question where I can set the location. Also, will geoshape use the default zoom level from the settings of the survey?
