A staff member of mine has published a two surveys; one Web one mobile/desktop. Both are using external selects (three levels) and use the same XLS Form code to access the select. The external select worked on Web form when published in Connect v. 2.5.44, but fails when published in a later version. We can navigate through levels 1 and 2 before it fails on level 3, the available selections are blank. It should be noted the survey works on mobile and desktop using the same code.
Is there a new limitation on levels of selects that can be performed using the Web form? We are going to try removing the external and try a cascade select to see if it works. I have attached the Excel file for the Web form.
Any help you can provide is greatly appreciated,
Chris Anderson
Florida Fish and Wildlife Conservation Commission
