I am trying to use Survey123 and Integromat and have followed all of the directions, side by side with the tutorials. When I run the scenario there is something wrong with the Create Feature Report that comes up empty so the HTTP module throws an error.
Integromat support just tells me "Is not being returned, therefore is empty and that's why you get the error, you don't get any url in the response. Sometimes the variables that the module shows that it returns, it's greater to the actual variables that you would get since sometimes depending on the use case it might return a part of the variables that it shows as mappable, which is the case here."
Not sure what that means.
Debby C
