We have a polyline feature class (in our enterprise sql geodatabase) with a couple attributes that have domains specified. During the usual manual editing of features, it works like a charm - users can only select one of the defined values in the attribute's domain. But the Field Calculator allows any (string) value to be placed in the field, including string values that are neither a domain code nor domain description. I get the same problem in Python code using arcpy.UpdateCursor.
If somebody starts an edit session, enters invalid attribute values (i.e. non-domain) into ~200 features and then saves the edits and walks away - ArcGIS doesn't even blink an eye. I have to start up the editor again, select those ~200 features (in my case, across 5 feature classes) and then run "Validate Features" to have ArcMap bark at me about "Field xyz attribute value yyy is not a member of coded value domain zzz".
Rather defeats the purpose of using a domained attribute.
What do others do?
