We recently upgraded our ArcGIS server to version 10.4.1. We installed the ArcGIS WebAdapter (IIS). We installed Portal for Arcgis 10.4.1. I can log into the Portal at https://abc.abc.com/portal/home. I can log into the server at https://abc.abc.local:6443/arcgis/manager. Under the manager I have created a Data Store and have validated the connection. I have published two services to the server and use them in a Flex Viewer Web application. These sites can be accessed through the internet and internally.
When I try to log into my Portal through Survey123 I use https://abc.abc.com/portal and get the following error:
Survey123 requires portal for ArcGIS 10.3.1 or later configured with Hosting Server and Portal for ArcGIS Data Store.
When I try to log into my Portal through Survey123 I use http://abc.abc.com/portal and get the following error:
Connection timed out (99)
When I try to log into my Portal through Survey123 I use https://abc.abc.local/portal and get the following error:
SSL handshake failed (6)
When I try to log into my Portal through Survey123 I use http://abc.abc.local/portal and get the following error:
Have we miss-configured something? Or am I trying to log into the Portal through the wrong URL? I'm a little confused.
