Hi, I am using the latest stable build of the survey 123 app on a 5th generation Ipad mini. When I attempt to add an image to the survey, the camera interface displays a distorted field of view, stretched a bit horizontally and cropped vertically. The actual image capture looks correct but it is hard to tell if we are capturing the full image because of the cropping that occurs in the view. Is there a setting for aspect ratio that needs to be set to work correctly with an Ipad mini? Display looks good on the iphone.
b
