Anyone know how interoperable the subject items are or are not? I have a web map that contains manholes VIEW, and built a custom URL that launches survey123 using Arcade. I did this so custom URL becomes dynamic from field values instead of a static field...
So, all goes well in the web map on my computer using both Chrome and IE. I view popup, shows arcade expression as hyperlink, hyperlink launches proper survey.
Also, in Collector (NOT CLASSIC), all goes well. I view popup, shows arcade expression as hyperlink, hyperlink launches proper survey.
However in Explorer, the popup shows everything necessary except the Arcade expression to launch Survey 123.
Thoughts why?
Thanks.
Arcade PopUp Syntax
arcgis-survey123:///?itemid=MYFORMID&field:MHsewershed=HR&field:MHnum=89&field:Location=206%20Adams%20Ct
Explorer for ArcGIS
