Hi All,
I have a survey that gets filled out in the field, then submitted (Collect). I also have Inbox enabled so that QA users can open the surveys previously submitted. My issue is that if the survey is opened from the Inbox, I want to make the QA section of the survey relevant, if the survey is through Collect the QA should not display.
If there is someway to detect that a survey is from Collect mode or Inbox? I have tried pulling in CreationDate and ObjectID from the hosted feature service to see if they exist, but I always get blank values. I assume these are can'y be pulled into a survey using Inbox?
Larry
