I have a current Collector and Survey 123 workflow referenced here that I'm wondering if I can improve by using the same feature service. The current workflow uses a feature layer in Collector with pre-established plot locations to call a S123 form. Survey 123 then creates a new feature layer with points in different locations that are not always close to the original plot location. However, I'm wondering if a plot point that I select in Collector can be edited by Survey 123 without S123 creating a new feature layer. Is this possible? If so, am I simply creating the survey from the existing feature service and adding fields to it as needed? Or do I need to create a consolidated geodatabase schema that has fields from both Collector & Survey 123 first before creating the web map & survey? Would it matter if multiple field staff would be syncing their S123 edits at different times (data overwritten?)? Thanks.
