Hello Robert,
I am not sure if this is the right place to ask you questions. I would like to ask you the question directly. I really like your identify widget (Identify Widget Version 2.7 - 02/23/2018 )..I have a question in using the widget.
In the configuration, i use cyan color for polygon boundary and hollow for polygon fill. When identify a feature, I choose all layers to be identified, I highlight the tax parcel in the identify result panel, the map is zoomed to my parcel with parcel is highlighted. Since I select identify all layers, the zoning polygon is highlighted. The highlighted zoning polygon and taxparcel polygon is mixed together, which is kind of misleading (see attached screen shot. What kind of customization can I do to highlight only the taxparcel feature when taxparcel is selected in the identify window? I would
