I am launching a form and passing the location coordinates to a read-only geopoint via Explorer for ArcGIS. When I pass the value directly to the attribute (e.g., arcgis-survey123://?itemID=***&field:harvest_loc={get_coords}), it takes it to the correct location on the map, but after a few seconds the location shifts to that of the location service (currently app-studio? - I'm working on a laptop). However, if I pass the coords to a separate attribute, then use them in the calculate field for the geopoint, the position is correct and does not change. I prefer the latter approach because it is cleaner, but I did not see a way to turn off the location service. Any suggestions would be appreciated. Thanks.
