When you have calculations that occur based on time in Survey123, does that calculation carry over when the survey is published to the web and used in AGOL?
For example, I have a survey that contains values that change depending on the date and I wondered if those will still work once the survey is published or do the values entered during the initial survey submitted stay static? If they are static then I suppose my other option would be to replicate the process using Arcade but I do not really want to do that since the calculations are done in a repeat group.
Thanks!
