I'm trying to launch and fill out parts of a survey123 form with attributes from a map service on Explorer, I've figured out most of it, but I'm having an issue where only one field in the survey is being filled out. It seems I'm doing everything right, but I can't get it to work right. I'm hoping someone here can help me out.
URL: arcgis-survey123://?itemID=6d45d37261524def90131c01fcae73d1&field:Well_Key={OBJECTID}&field:Project={Project}&field:Well_ID={Well_ID}&field:Well_Material={Casing_Material}&field:Casing_Diameter={Casing_Diameter}&field:Installed_Depth={Depth}&field:Screen_Height={Screen_Height}
Survey123 section to be filled out from attributes:
| hidden | Well_Key | Well_Key |
| text | Project | <center><b>Project</b></center> |
| text | Well_ID | <center><b>Well ID</b></center> |
| date | Survey_Date | <Center><b>Date</b></center> |
| start | Survey_Start | |
| end | Survey_End | |
| select_one staff | Personel_Present | Staff |
| hidden | Auto_Stable_Meter | Auto Stabling Meter? |
| begin group | Well_Construction | <center><b>Well Construction</b></center> |
| select_one material | Well_Material | Well Material |
| decimal | Casing_Diameter | Casing Diameter |
| decimal | Installed_Depth | Installed Depth |
| decimal | Screen_Height | Screen Height |
Feature Attributes:
Software:
Map Service hosted on Arcgis online, published from Arcmap 10.5
Survery123 form developed on survey123 connect v 3.3.51 on windows 7
forms tested on Samsung S7 android version 8
