Is there a way to have Survey123 not collect a geopoint if it is not needed? I created a survey that has a repeat which needs to take a geopoint if a rare species is found. If it is not found I do not need a geopoint. However, it seems that Survey123 is collecting a geopoint every time whether I find something or not.
Similarly, I have another survey that might require a radius search or a transect search. I have an initial geopoint for either the center of a radius search or the start of a transect search. Then there is a second geopoint in a repeat to take the end of the transect. However, the second geopoint appears to be being collected for the radius search as well, when it is not needed.
Is there anything I can do to work around this?
Christina
