Is there a way to set dynamically the label content for a Group or note, or even the hint contents?
Below is an abbreviated version of my test survey. The survey compiles and loads fine, but there is no content, i.e. there is just empty space, where the Group header and note should be.
When i try to use dynamic content in the hint field, i get some different behavior depending on where (or if) a variable is used in the string.
