I have a fairly large form with calculations. At first, some of the calculations worked in Connect and the Android field app, but not in iOS. I added the coalesce function to some of the calculations, and that made them work in iOS. However, after adding coalesce functions to the final field that was giving me problems, now the form crashes in iOS, but still works in Connect and Android field app. Specifically, adding coalesce to the calculation in field 435 seems to be the tipping point, as without it, the form will not crash, but the calculation will not work. Any help to get the calculation in field 435 to work in iOS without crashing the form would be greatly appreciated!! The two versions of the form are attached.
Thank you,
Mikala
