I have created two surveys for submitting data related to coral reefs. One is for biologists submissions which is more detailed, and the other is a citizen science survey. Both of the surveys are connected to the same hosted feature layer. The biologists need to be able to edit the data and perform QAQC on the publicly submitted data, so I also created a public view layer to add data, and a fieldworker view layer for the biologists with editing permissions. My question is, in order for this to work, the main hosted layer must be shared publicly, but must also have editing enabled. Is this a good idea (since esri give me a warning that it is not), and if not, how do I get around it? In the documentation for Survey 123 it explicitly states "The surveys and hosted feature service must be shared publicly, which in turn, permits anonymous submissions".
I already created a group for the biologists, and they must login to be able to edit the data using the Survey form, so is that the correct (best) way to handle this?
Just want to know if I am going in the right direction, or is there a better way to do this?
Thanks!
