I'm trying to split a string and label only a particular part of it. (I'm using Python because Arcade doesn't seem to have sufficient capability to specify which part of the string I want to label, but that's a separate gripe.)
This expression cannot be verified if any nulls are present in the field:
<SPAN class="keyword token">def</SPAN> FindLabel <SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">[</SPAN>ValMap<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">[</SPAN>ValMap<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"_"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
You'll get this error:
But you can get around that by putting an if statement in the expression:
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">[</SPAN>ValMap<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">!=</SPAN> None<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">[</SPAN>ValMap<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"_"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But then I thought, "Wait, I shouldn't have to filter nulls in the expression; that's what the SQL query on the label class is for!" I had already applied this filter to the label class:
<SPAN class="keyword token">SELECT</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="keyword token">FROM</SPAN> FeatureClass <SPAN class="keyword token">WHERE</SPAN> ValMap <SPAN class="operator token">IS</SPAN> <SPAN class="operator token">NOT</SPAN> <SPAN class="token boolean">NULL</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
For testing, I applied the same SQL query to the definition query of the layer. Either way, it doesn't prevent the error on the expression. I thought maybe this is a bug in Pro but the same thing happens in ArcMap, which makes it less likely to be a bug(?). So now I just want to understand the mechanics of SQL queries on label classes and layer definitions, and their apparent (non-)effect on label expressions.
