I'm on 10.6.1 of portal. Recently my user, group, and content data got messed up by a script that was attempting to copy data from one environment to another. Now I cannot login to portal through the browser at all. In fact, if I go to the normal URL, the content you'd expect to see flashes by and is then replaced with a sign-on screen. I try the admin login credentials, but it just refreshes back to the sign-on screen.
What I'm asking is this... since I cannot login as admin, is there any other way to do a point in time restore of the portal's postgres data (I know the date when it all worked before the script was run). If so, can I get a simple 1, 2, 3 procedure?
Thanks in advance.
Btw... after that data mess up occurred, even rolling back to previous snapshots (using vCenter/vSphere) does not fix the problem for some reason.
