HI All,
Publishing an image service to ArcGIS Server to be used as a map service in Geocortex. The image service is successfully published using a mosaic dataset. Have published from both FGDB and SDE just to trouble shoot.
The issue is when I add the service to Geocortex I can just a checkerboard for the image. I am trying to determine if this is an issue with the steps taken in publishing the service on the ArcGIS side or if this is an issue within Geocortex. I am posting this in both forums.
During the publishing process I get no errors or warnings and get a smooth publication to Server. Images are referenced, mosiac dataset. In Geocortex they appear in the right geographic location - just as a checkerboard and no image.
Thoughts?
THanks,
Mike
