Hello,I am trying to disable the url parameter popup while I am using the measure widget. I am able to hide the window when I click the measure widget and when I double click to end, but DURING the measurement the url parameter popup keeps........well...........popping up. Any help would be appreciated. Here is the code below I have been working with from the Javascript sample section in resources.arcgis.com.<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior
of the samples on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"
<title>Parcel Locator</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.esriScalebar {
padding: 20px 20px;
#map {
padding:0;
</style>
<script type="text/javascript">
var djConfig = {
parseOnLoad: true
</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.dijit.Measurement");
dojo.require("esri.dijit.Popup");
var map;
var parcels;
function init() {
//apply a selection symbol that determines the symbology for selected features
var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([111, 0, 255]), 2), new dojo.Color([111, 0, 255, 0.15]));
var popup = new esri.dijit.Popup({
fillSymbol: sfs
}, dojo.create("div"));
map = new esri.Map("map", {
infoWindow: popup,
slider: false
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/");
map.addLayer(basemap);
//apply a popup template to the parcels layer to format popup info
var popupTemplate = new esri.dijit.PopupTemplate({
title: "{PARCELID}",
fieldInfos: [{
fieldName: "SITEADDRESS",
label: 'Address:',
visible: true
fieldName: "OWNERNME1",
label: "Owner:",
visible: true
//add the parcels layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected parcels
parcels = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/1", {
outFields: ["*"],
infoTemplate: popupTemplate,
mode: esri.layers.FeatureLayer.MODE_SELECTION
parcels.setSelectionSymbol(sfs);
//when users click on the map select the parcel using the map point and update the url parameter
dojo.connect(map, 'onClick', function (e) {
var query = new esri.tasks.Query();
query.geometry = e.mapPoint;
var deferred = parcels.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) {
//update the url param if a parcel was located
if (selection.length > 0) {
var parcelid = selection[0].attributes['PARCELID'];
//Refresh the URL with the currently selected parcel
if (typeof history.pushState !== 'undefined') {
window.history.pushState(null, null, "?parcelid=" + selection[0].attributes.PARCELID);
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(e.mapPoint);
dojo.connect(map, 'onLayersAddResult', function (result) {
// Add a link into the InfoWindow Actions panel
var emailLink = dojo.create("a", {
"class": "action",
"innerHTML": "Email Map",
"href": "javascript:void(0);"
}, dojo.query(".actionList", map.infoWindow.domNode)[0]);
// Register a function to be called when the user clicks on
// the above link
dojo.connect(emailLink, "onclick", function (evt) {
var feature = map.infoWindow.getSelectedFeature();
var url = window.location;
var emailLink = "mailto:?subject=Parcel Map of :" + feature.attributes.PARCELID + "&body=Check out this map: %0D%0A " + window.location;
window.location.href = emailLink;
//When users navigate through the history using the browser back/forward buttons select appropriate parcel
//https://developer.mozilla.org/en/DOM/Manipulating_the_browser_history
window.onpopstate = function (event) {
var parcelid = getParcelFromUrl(document.location.href);
if (parcelid) {
selectParcel(parcelid);
} else {
parcels.clearSelection();
map.infoWindow.hide();
//if a parcelid is specified in url param select that feature
map.addLayers([parcels]);
dojo.connect(map, 'onLoad', function (theMap) {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
//extract the parcel id from the url
function getParcelFromUrl(url) {
var urlObject = esri.urlToObject(url);
if (urlObject.query && urlObject.query.parcelid) {
return urlObject.query.parcelid;
} else {
return null;
//select parcel from the feature layer by creating a query to look for the input parcel id
function selectParcel(parcelid) {
if (parcelid) {
query.where = "PARCELID = '" + parcelid + "'";
var center = esri.graphicsExtent(selection).getCenter();
var extHandler = dojo.connect(map, 'onExtentChange', function () {
dojo.disconnect(extHandler);
//zoom to the center then display the popup
map.infoWindow.setFeatures(selection);
map.infoWindow.show(center);
map.centerAt(center);
function disablepopup() {
<!--MEASUREMENT TOOLS-->
var measurement = new esri.dijit.Measurement({
map: map, onClick: disablepopup
},dojo.byId('measurementDiv'));
measurement.startup()
<!--DEACTIVATES MEASUREMENT TOOLS AFTER MEASUREMENT-->
dojo.connect(measurement, "onMeasureEnd", function(activeTool,geometry){
this.setTool(activeTool, false), map.infoWindow.hide()
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<!--CENTER and RIGHT CONTAINER-->
<div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
</div>
<div id="bottomPane" dojotype="dijit.layout.ContentPane" region="bottom">
<div id="bottomPane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement Tools', closable:'false', open:'false'">
<div id="measurementDiv"></div>
<center><button dojoType="dijit.form.Button" iconClass="eraserIcon" onclick="map.graphics.clear();">Clear Measurement</button></center>
</div>
</body>
</html>
Thanks!!
