I am trying to create a web based map viewer which consists of a single Map Service with no base map layer.
I have managed to do this with the 3.15 API by specifying no base map, however when I try to do this with the 4.0 API beta the layer is displayed but I get the following error on load:
Uncaught TypeError: a.constrain is not a function |
Additionally when I try to zoom or pan the map I get the following error:
Uncaught TypeError: this.constraints.constrain is not a function |
Here is my javascript code:
var map;
var layer ;
var view;
require(
"esri/Map",
"esri/views/MapView",
"esri/layers/ArcGISDynamicLayer"
function(
Map,
MapView,
ArcGISDynamicLayer,
layer = new ArcGISDynamicLayer({
url: "http://my.service.url"
map = new Map({
layers: [layer]
view = new MapView({
container: "map",
map: map,
ui: {
components: ["compass"]
);Also if I put in a basemap everything works correctly.
