Hello all,
I'm trying to create a survey in Survey123 Connect that autopopulates a value with both text as well as a number.
How I would like the survey to work is to take a subset of points in section 1a. When in section 1a, I would like the first point to render as 1a01, the next as 1a02, and so on and so forth. In addition, the data needs to be exported to a csv file. Originally, I created a note that would display the section and then used the position(..) to show the correct number, which worked fantastically in the survey itself. However, the autopopulated section did not export to the csv file at all.
I'm fairly new to Survey123, so I'm sure I'm missing something. I've tried playing around with the formula "selected-at(${point_name}, position(..))", but that doesn't show any values at all (potentially because I'm confusing the system with trying to have both a text value and a calculated numerical value).
Anybody have any thoughts?
Jess
