I'm doing a spatial join with attribute matching between 2 point feature classes (schools and 911 address points) to verify that schools have the correct address. I set up a 1-1 join with closest match option, and set school address field and 911 address field as my match fields.
I have a case where a school point and an address point are coincident, but the school address for that point does not match the 911 address. My hope was to flag cases like this so I can correct the school address to match 911 points. However, the spatial join tool matched the school point to another 911 point feature 2 miles away in a different town, because it shared the same (incorrect) address that I had for the school. If I do a straight-up spatial join without attribute matching, it joins the school to the coincident 911 address point.
Maybe I'm misunderstanding how the tool works. I'm assuming that in a Spatial Join, the spatial relationship should be the important bit (i.e. closest point), and then if the specified attributes match candidates for that spatial relationship, the feature is joined to the target. If the spatially closest feature doesn't have matching attributes based on the join and target fields, it seems like it just shouldn't join. Then you can search for null values and see why it doesn't match. According to ArcGIS Pro documentation,
Also, that's how it's described in the InProductPlan post of https://community.esri.com/t5/arcgis-pro-ideas/spatial-join-by-attribute-match-fields/idi-p/1185961
and the Blog that's referenced there. Does anyone know how exactly the tool works when you use Attribute Matching?
My school dataset is relatively small, so for this situation I can get around it by doing just a spatial join to closest, then in the resulting attribute table finding cases where the addresses don't match. But I have another larger project where this functionality would be very helpful if it works correctly and I can trust the results. Any insights would be appreciated.
