is it possible in the Survey web designer to use a Single select option to then control what choices are available in a Dropdown if some of the single select choices also allow same matching selection in the dropdown.
I am not very experienced with the Connect app but discovered there is a way to do a one to one match of sorts for picnic tables but not for bences.
Below is the logic I would like to achieve if possible?
| Feature Type | Rule | Model |
| Drop Down (Single Choice) | | Drop Down (Single Choice) |
| Bench | IF Bench OR Available space for a bench OR Vacant but reserved | Streetmaster Clarendon Green |
| Picnic Table | IF Bench OR Available space for a bench OR Vacant but reserved | Cavendish |
| Available space for a bench | IF Bench OR Available space for a bench OR Vacant but reserved | Phoenix Jubilee Sea |
| Vacant but reserved | IF Bench OR Available space for a bench OR Vacant but reserved | Phoenix Bench (no arms) |
| | IF Bench OR Available space for a bench OR Vacant but reserved | Plymouth |
| | IF Bench OR Available space for a bench OR Vacant but reserved | Glen Ogil |
| | IF Bench OR Available space for a bench OR Vacant but reserved | Rub/Queens Wave Bench |
| | IF Bench OR Available space for a bench OR Vacant but reserved | Haz Queen Mother Bench |
| | IF Bench OR Available space for a bench OR Vacant but reserved | Unknown Bench |
| | IF Picnic Table | Hillside Picnic Table |
| | IF Picnic Table | Hillside Picnic Table – DDA |
| | IF Picnic Table | Unknown Picnic Table |
So for example if user selects Bench from the Single choice they can only select from the dropdown 'Plymouth' and if they select Picnic Table, 'Hillside Picnic Table'
I hope this makes sense.
